OEM parts incorrect?
Hook up the pee tube back to where it needs to be, that resrtiction is an engineered discharge diameter that helps the cooling water pull more heat away by slowing down the water flow through the block. If you can hold your hand on the exhaust plate and the aluminum welsh plug on the starboard side of the block without it burning you, you should be good to go. If you have a laser temp gun, you should be around 100-110F at diffrent points around the block.
I have the hose hooked up, but didn't hook up the pee tube. (I didn't read this until after I did it)
Anyway, turned motor on, water was coming out well. Hand on exhaust plate not too hot. Let it run for about 5-10 minutes and at about 10 minute mark water stopped coming out, exhaust coming out of hose, and temp went way up. it seemed like it thermalled.
I'm gonna let it cool down and attach the mid cover(with pee hole attachment) and see if that makes a difference. It seems that maybe there is an issue somewhere.. So strange. Again, thinking that motor was probably operating like this before and it just got worse until it hit a point where it was way too hot
I have the exact same engine in the collection 1984 7.5, Does your engine have the 3 blade short exhaust hub propeller? I have been critized for this conclusion on here before. The exhaust gases from that short hub propeller dump exhaust directly under the water intake grid and fills the water entry with exhaust gases creating loss of cooling effciency and the engine starts to run hot in the test tank. Put the engine in forward gear slighty above idle; that pushes the exhaust away from the intake grid, watch what happens to the temp. Starts running cool.
Man. That is crazy. Well, I just went out and tried again. It was definitely overheating, and this time seemed quicker. I'm assuming the internals were still warm so probably didn't have as far to go
I'll let it cool down and try it again, in forward gear.
Man. That is so crazy. Thank you so much! I would never know this.
So, it seems that the engine is totally cool(a teeny bit hotter than I would like, but definitely in the realm) and you are totally right; it is the exhaust going back into the water pick, which explains why it worked fine for a decent amount of time and then starting thermalling.
So, it sounds like its in the ballpark of where it should be, and I probably shouldn't mess with getting the exhaust cover off. I
I live on the Puget sound, where the average water temp is in the low 50's, so despite the salt, it does keep the motors a little cooler
No need to remove that cover, brother, throw that bad boy on a 14' jon boat and have fun! You have learned the in and outs of a 1962-1985 Mercury twin cylinder cooling system. Congratulate your team!... For someone who hasn't twisted wrenches on an outboard before, you did pretty damn good. If you ever make your way down to Florida, give me shout! This is what I love about forums...I've met some really great people and new friends.
Well, I definitely appreciate your kindness and patience in walking me through the steps to figure this out! Same to you. If you are in seattle area, drop me a line and I’ll take you out!
Real
I want to go out in the Puget sound with that 7.5 Merc and catch a big ass Halibut that we have to shoot before we bring it in boat and fly those fillets back to Florida.... That is my wish...
Real
Well, thanks again for your kindness and patience in walking me through all these steps. I love learning new things, and slightly demystifying motors has been pretty cool(though my tool collection is getting out of hand!) Let me know if you are up in Seattle area and I will take you out!
This is the boat the motor lives on. Its kind of a cool story, if you want to hear it.
I was on tour. My wife was having dinner at our friends house. She calls me and says " they have a boat we can have!" I asked here 2 questions: "Does it run" "Is the floor solid?". She answered yes to both. When I got home, I saw a completely destroyed boat. It had the original 1955 Evinrude on it..Wasn't frozen, but barely alive. Floor was rotten, stringer and transom were rotten. The hull had tons of patches over gelcoat where they had used various epoxies and such and then just painted over it.
I remember getting pretty pissed as it sat in our driveway. Like a lot of my "hobbies" they start out of necessity. It was either haul it to the dump and pay the $450 fee or try to find how to get it running. I had NO IDEA what I was in for.
Really long story short, having never done any of these before, I tore everything out, and figured out, with a ton of research, how to build better stringers, a solid transom, good floor with improved fiberglass from original, and re-gelcoated the whole hull. That was the most insane of all of it. Gelcoat is weird stuff and if you don't have the right tools(in my case mostly cheap chinese tools) it is a series of orders harder.
I made so many mistakes along the way, redid quite a bit of it. I ended up having to build a garage to store it in, and then a couple of winters ago, enclosed the garage so I could re-gelcoat the hull, as my first time hadn't really stuck.
I rebuilt the Evinrude lower end, got into the engine a bit, and got it running. I was getting pretty crazy on the restore when my commercial fishing buddy came over and talked some sense into me. He said that unless I wanted to work on the motor constantly I should get something newer. I didn't have money for a new motor, so found a '88 merc TOP 115(also the kicker) for a pretty good price. I rebuilt carbs and fuel pump and redid the timing. She's been a great motor for me! A little finicky to start, but runs pretty damn well, all said. I take really good care of her, and know at some point she will have to be retired. Ive done my best to keep her clean, but have a trim motor thats about to rust through and some bolts that if I try to take them off would definitely be going to a machine shop.
We've had a lot of fun on her, and now I got my little trolling motor back!
Ian
The halibut aren't in the sound. We have salmon(during certain times) and some other fish, occasional ling cod. If you are serious about halibut you have to go off the coast. My friend had a charter they would do that was like $250 per person and you'd come home with 4-500 dollars worth of halibut!
