Yes, temporaryThe color of the thread locker is less important than whether it's specified for temporary or permanent use.
My response was confusing. What I meant is that I can use the flush fitting into the water tube(where it would connect to the water pump.)The flush fitting will test for water circulating through the block, what is will not test is if the plastic washer that sits on top of the water tube / grommet, that is sandwiched between the powerhead and mid section has beed distorted or melted from overheat that would restrict waterflow coming through the water tube into the block. The powerhead needs to be removed to validate the condition.
Yes. Water was definitely high enough. When I put motor back together, I tested it in a trash can. Didn’t measure, but probably 18-24” above impellerWater must be 6 / 8" above impeller in a test bucket.
Without knowing specifically what you are talking about(tenuous grasp on some part names) this is kind of what I’m thinking. Is this something I would be able to see? I don’t know enough about the cooling system to diagnose this.A hole in the exhaust plate forcing exhaust gases back into the cooling passages preventing the water to circulate in the block, the other would be a breach of compression from corrosion in the cylinder cooling area typically in the blind pocket next to where the spark casting is. Very common in saltwater engines that weren't flushed properly. I've had a pile of those blocks in the past, but that condition usually shows up as water on the spark plug.
The first thing I did before working on the motor was to test compression. Both cyclinders were a little over 120psiA hole in the exhaust plate forcing exhaust gases back into the cooling passages preventing the water to circulate in the block, the other would be a breach of compression from corrosion in the cylinder cooling area typically in the blind pocket next to where the spark casting is. Very common in saltwater engines that weren't flushed properly. I've had a pile of those blocks in the past, but that condition usually shows up as water on the spark plug.
So, it sounds like this is the next step. I'm assuming I should removed the powerhead to do this. I'm gonna look at the waterpump one more time to make sure there isn't something there.The exhaust baffle plate separates the dry hot exhaust gases exiting the cylinder ports and the cooling water circulating between the plate and exhaust cover. This cools the hot exhaust and mixes with exiting water has it heads into a tuner/adapter or just dumps into the midsection and out through the propeller hub. You can actually see the seam of the plate and cover in right of your photo. If there is a hole in that thin stainless plate, it can push hot exhaust gases back into the coolant water flow and interupt or stop water from flowing up the block and into the powerhead causing overheat. The challenge with finding this out is that the exhaust cover bolts are notoriously stuck and can break easily without heat (MAPP) gas torch and finesse and slowly working the bolts out, tighten and loosen until they unscrew, this can take hours to do, but saves a trip to the machine shop to get them drilled and re-tapped. The water cover where the spark plugs are is equally as challenging. I've lived in Florida saltwater my whole life so this stuff is second nature but I still break a screw every so often.
And, just to confirm, I'd be removing this.?So, it sounds like this is the next step. I'm assuming I should removed the powerhead to do this. I'm gonna look at the waterpump one more time to make sure there isn't something there.
Any tips on what you do with the torch and bolts? Ive avoided this to this point for this exact reason.
Yes. It seems that every channel is pretty clear. I checked everything also with compressed air, and there was quite a bit of pressure coming out of the ports.Before you take the plate off, are you able to get water through using the flush attachment to the watertube and see water coming up through the water tube with the powerhead removed? looking for a piece of impeller vane lodged in the watertube.
you mean those seals that have the round lip to hold them? If so, yes. Both of the seals are there.Are the grommets in place in the water pump housing where the water tube fits nice and snug? Are the grommets in place between the intake grid under the cavitation plate, the cross over pipe and the grommet going into the pump base nice and snug? Just trying eliminate low hanging fruit.
I did briefly when checking earlier and it didn’t seem super hot. I’ll check again when I’m back from a meeting.Can you hold your hand on the exhaust plate while the engine is running? You should be able to without discomfort
