Hello,
I've been having a heck of a time rebuilding the water pump on my 1985 7.5 HP.
I've been using the Marineengine parts list that aligns with the serial number on my engine, but seem to be running into some incongruence with the parts.
I ordered the water pump rebuild kit
and the impeller key
28-8M0032835 - Key
I've attached a photo and you can see that they impeller key(packaged in OEM bag with correct part number) is much too big for the groove on the impeller.
I also had a similar issue with the shift shaft oil seal not fitting into the bushing. The bushing was in the motor when I bought it, so I can't 100% be sure that it was the correct bushing, but it was a working part when I disassembled it, so I would assume it was. I warped the bushing trying to get the seal to sit(my bad--lack of experience) but had assumed the part was correct, and was following the instructions on the service manual.
Has anyone had this experience with OEM parts bought from Marinengine?
Ian
| 18-3446 - Water Pump Kit 46-70941A3 |
28-8M0032835 - Key
Ian
