James Cole
Administrator
Do you need to…
Here are all the helpful resources we have online to assist you!
Model Identification Guides
Engine Parts Diagrams & Schematics
Engine and Outdrive serial numbers are found on ID tags. See above.
Original MerCruiser Mercury Marine Parts
Aftermarket BARR Exhaust Manifolds Elbows & Risers
Aftermarket Parts by Sierra Marine
identify your engine?
find repair or troubleshooting information?
place a parts order here on MarineEngine.com?
NOTE: The engine and sterndrive unit will each have their own separate serial number.
Engine Serial Number: The serial number tag is located near the starter, by the flywheel housing, on the rocker arm or flame arrestor cover.
Transom Plates: The serial number tag is located on the inner transom plate inside the boat, or on the upper swivel pin.
Sterndrive Serial Number: The serial number tag is located on the upper drive shaft housing.
- Parts diagrams - by serial number
- Engine parts diagrams by Model, Cu.In., Liter
- Outdrive parts diagrams by model
- Engine Accessory Item diagrams
- Application Guides
- Full Sierra Catalog online
- Download PDF Catalog (large download - 1,200 pages!)
- Propeller Finder – by Solas
- Replacement Lower Unit Gearcases
- Replacement Outdrive Alpha One
- Replacement Outdrive Alpha One Gen II
- Throttle & Shift Cable Finder
