Im working on a 2003 BF200a with 1685hrs, engine will not start. I've narrowed it down to injectors are not firing, what I've checked:
- Dr.H honda diagnostic comes back with no error codes
- Fuel pressure is 48psi when you turn the key on
- All fuel filter replaced
- Getting 1.9oz fuel flow back threw the return during the initial fuel pump cycle when key is turned on(book spec is 2oz)
- has good compression
- has spark
- will try to start on ether
- all fuses are good
- checked all connectors
- has continuity from injector plug signal wire to ECM plug on all injectors
- Ran injectors threw my cleaning/testing machine, all are good
Just thought of, I need to see if I have 12volt reference to my injectors.
- has spark
