I upgraded the 2003 Honda 50s on my SeaCat Sl1 to identical 1998 Honda 90s this spring and so far so good. The only issue that I have is that the port engine gets 6000+ rpms while the starboard engine can only get 5500 rpms. After putting 60 hours on the boat so far the max rpms have now dropped to 4500 rpms on that starboard engine. I'm trying to figure out what the issue is and know its either spark, air, or fuel (haha). Its interesting because I've had other carb'd engines that have bogged before (usually carbs), but this one just seems to hit the max rpm without making any noises or sputtering and just won't go anymore.
This is my assessment to date:
1) Both engines are mounted at the same height and have the same props.
2) I confirmed that the throttle linkage is roller is moving all the way to the open position at WOT as compared to port engine, so it doesn't appear to need adjustment. Although its possible the carb butterfly valves aren't fully opening?
3) I've replace the onboard fuel filter, external fuel water separator, and drained carbs several times.
4) The carbs may also need a rebuild. The previous owner said he had rebuilt the carbs himself in the last few years, but I know the honda carbs are a PITA to tune. I did run some Seafoam spray to decarb the engine but I couldn't get the airbox off fully and the engine didn't seem to sputter or choke like it should have been as when I've done this on other engines. There doesn't appear to be an issue with the airbox.
5) Is there any way to test the fuel pump performance?
6) Is there a simple way to test the stator/alternator with the voltmeter for static resistance and/or make sure its putting out full voltage under load? I've noticed on the dash that the starboard engine is putting out slightly less (0.25 - 0.5) volts than port engine, but not sure if that's just error in the 20 year old gauges/wiring harness.
7) I do have a spark plug tester and that is also on the list to test...
Any other ideas would be appreciated!
