BF90D running issues, surging or stumbling at mid range
MATPOC
New to me 2017 BF90DK4, starts and runs fine, runs great at WOT around 6,000 rpm, accelerates fine from idle or near idle and from above 4,000 rpm, no hesitation, however at around 2,000 rpm it starts surging, about 10 second intervals it drops about 300 rpm and slowly picks up, holds RPM for 5-10 seconds and drops again, slowly accelerates and repeats, no problem at 3,000 rpm, then same problem comes back around 4,000 rpm, like someone is playing with a throttle, goes away above 4,500 and no issues all the way to full throttle.
Another issue is the acceleration, same window, above 2,000 below 4,000 if I try to accelerate there is a hick up, feels almost like a bang, no problem below 2k or above 4k, I can accelerate from stand still and it's smooth, but if I'm running 3k and give it gas it has a very noticeable jump, it bucks, and then accelerates hard no issues.
No waning lights (this one has 3 red and 1 green bulb) I got new plugs coming an will do compression test as well. New fuel filter, pretty sure it's not fuel related because of the narrow range where the problems occur, if it was starving it wouldn't be running that well above 4k.
Hi,
Please know I have no experience with this outboard. Just speculating on the symptoms you have listed.
If at all possible, I think you would be best off getting a scan with the Dr. H software at a competent shop. But I know circumstances don't always allow for perfection so I'll offer some guesses.
Based on what you've said, it sounds like there could be a bad spot or two in the Throttle Position Sensor. Often referred to as a "glitch". This often appears as a reliably repeating issue such as you've described.
The TPS can have bad spots in it, cause problems and not trigger an engine warning or log a code.
A GOOD mechanic that KNOWS what he's doing, can interrogate the TPS with a labscope. Ocasionally faults can be seen with an ohmmeter but an oscillocope is much faster and more likely to capture what is actually going on. Even the engine ECU, hooked to Dr.H, might not catch what the O'scope can see.
This might also be caused by a dirty throttle body. Cleaning it is something that can be done as part of a process of elimination but specific precautions need to be observed when doing that.
It apperars that the MAP sensor is mounted directly to the TB so its not unreasonable to think that dirt in that area could be interferring with the sensor's ability to provide accurate load information. That can "confuse" the ECU and adversely effect fuel delivery.
It's never good to have preconcieved ideas or get "tunnel vision" about what's happening when trying to diagnose a problem like this. These outboards can create some intense vibrations at various rpms while running and a poor connection or comprimised wire could be affected. If this occured in the fuel pump circuit, for instance, it COULD create a fuel delivery issue at varying speeds. I don't know. Again, just speculation. But testing fuel pressure during the occurance should not be ruled out.
Just a couple of thoughts.
I hope you can get it sorted without too much pain.
Good luck.
I agree, A scan is likely the best option to start with.
Do the plugs look clean? How many hours on it? Do you spend a lot of time at low rpm or idle?
What is the quality of your fuel?
My first thought from a common sense point of view is dirty fuel system (varnish from running at low rpm) or valves needing adjustment. Or bad fuel- do you have a large internal tank?
You could run a fresh portable tank of fuel, high test and ethanol free if available, with a high dose of something like Sea Foam in it. Burn a tank of that at high rpm, 4000 or above, see if anything changes.
First of all, appreciate the replies, really miss old days when online forums were a place for exchange of information and ideas, unlike current social media that is mostly clickbait.
Little more info as I'm starting to figure this out:
Engine is 2017 BF90DK4 which is NMEA2000 compatible, however the harness and ECU have been replaced with 2016 or earlier non-NMEA model, so they modified the harness. It's a proven method that had worked in the past and this engine ran fine on the stand, so seller being an honest guy, is working with me to solve this issue.
I spent last night on my laptop, well past midnight, searching for info related to those two systems. Best I can tell there are minor differences, mostly backwards compatible, the one big issue that that I have a single oil pressure "sensor" on the engine block for a NMEA system so it can monitor the actual oil pressure, it's a 3 wire sensor with ground, 5V reference and signal to ECU.
Meanwhile the harness has provisions for 2 oil switches, both are on/off type, one grounds out to the engine when it looses pressure (idiot light) and the other is for ECU limp mode, also simply grounds out to ECU itself. Not a straight swap as one is 1/8 NBPT thread (tapered so it seals with teflon tape type) and the other is M8x1.25 with an o-ring, so I would need an adaptor.
Why am I looking at oil switches? Wondering if at a certain RPM the "sensor" wired to older ECU can trigger the limp mode as the principle of operation is vastly different.
Prior to buying this motor I have never seen one up close, new to boats in general, and now I'm almost an expert, especially since I do have lot's of professional experience with cars, and this BF90 powerhead is basically the motor that is used in a Honda Fit (Jazz in Europe) although peripherals are vastly different.
Fuel system is OK, I had another engine on this boat and I kept a brand new tank and water separator that was installed on the boat, it's clean and fuel is new non-ethanol that I was using 2 weeks ago with a Yamaha that was on there without any issues.
I downloaded a manual, although it's for NMEA engine, and have been checking sensors for resistance, so far so good, will have to get it running to do the TPS and MAP as they require 5V reference, might try to hunt down a scope as I only have a multimeter. Both of my parents are electronic and communications engineers so I'm very familiar with oscilloscopes and smell of rosin solder :) but they both retired long ago and don't have any of their old equipment, also my dad's old scope was a size of a microwave (I'm 52 they are almost 80)
I found several iffy connections where the wires were simply twisted together, and although they all look good I am going to solder and heatshrink everything and hope it fixes the issue...
Plugs look good, might be a touch lean, got new ones anyway
Coils are clean, no burn marks
Will do compression check for good measure
I also checked the dreaded VST grommet, not an issue on this one.
Throttle body and intake silencer are kinda dirty, could be a result of me trailering the engine with cover removed down the dirt road on the way home, I'll clean it for good measure anyway.
Yes, you know way more than I do about this. NMEA is something I've never dealt with.
I have 2 or three of those "microwave sized" analog scopes though and they are probably too slow to be of much use these days unless you're looking at tube amps or something. I'd preobably be electrocuted if I tried using one :unsure:
Hope you NAIL it! Let us know.
Most of what I learned was last night, I can't leave things half finished so I was up late researching and now I'm paying for it, exhausted...
NMEA is basically a CAN BUS that is compatible with many new gadgets, I just bought a chartplotter specifically non-NMEA because it was half price of a newer "N" (network) model because ultimately I just want to go from point A to point B without hitting anything, I don't even have a radio on my boat, removed and tossed it in the trash... I want to unplug when I'm on the lake, use phone only for taking pictures, like the one below from 2 nights ago ))
Got to admit it's a neat system because you can just plug compatible devices along the wire with a use of a "T" and IN THEORY they seamlessly mesh together using a universal communication protocol, so for example if I had N chartplotter and NMEA ECU I could buy a $100 network starter kit from Honda and my chartplotter would show RPM, oil pressure, trim, engine hours, etc. I never tried it, so I can't say for sure if it's that easy, but in theory it should be plug and play.
CAN (controlled area network) is quite brilliant, it was invented in early 80's by Bosch and released on the late 80's license free, first car with CAN BUS was a 1991 Merc S class that cost more than my house did at the time (NO JOKE! they sold for $70-140k depending on model) and now I can piggyback a CAN on any 2017+ Honda engine for about $100.
Ordered HealTech, supposedly it can go live data...
Also I have a scanner that can do Honda bikes and that also supposedly can do outboards as well, so I ordered an adapter, hoping one of those two things will work.
I'm away for work most of the week, every week so all I can do is contemplate my course of action while I'm 200 miles away from the boat
VTEC equipped? (Mr.Google says yes)
Just thinking about the symptom but looking at SI for an older BF 225.
The high speed cam actuator on those is supposed to apply pressure at 4500 rpm and release at same as speed drops back down.
If the 90 is similar, it makes me wonder If the acuator could be stuck in "apply" and she's hung in high speed mode.
I know you say it runs good at low speed but maybe as the fuel pulses increase with added throttle, the difference might get more dramatic well above idle.
Your comment "there is a hiccup, almost like a bang" when you throttle up had me doin' the old head scratch so trying to come up with ideas. It might explain the 10 second, 300 rpm hunting it's doing as the ECU trys to make the O2 happy.
The valves being iheld "more open" at lower speed and running lean, then getting a gulp of enrichment could create a "pop" as the added fuel briefly sees the air it wants to make a bigger fire.
You would think she might start ok like that but be too lean to idle smoithly so probably just another goofy theory from your's truly.
And, the O2 would see that and probably be squawking and turning on the MIL But ...maybe not
Hope I'm not just throwing a flopping, slippery RED HERRING on the deck to interfere with sleep.
I've seen posts here and on other sites that people with the HealTech like them. I don't know if they have bi-directional capabilities but if the info is good, you will probably have what you need to solve this mystery.
Safe travels
I don't think it's a VTEC issue, but it's definitely a VTEC motor from a Honda Fit (Jazz for non-us market)
The hunting could be O2, especially since the wire splice that was made is very iffy, might be vibration that was causing it to have intermittent signal, but not bad enough to throw a code...
Plugs do look lean, I say so because with non-ethanol I expect some color and those are pure white, but definitely not new, there's some ash on the inside surfaces of the metal threaded cylinder.
I'm heading back tomorrow and I'll redo all the splices, hopefully weather cooperates and I get to test it out, if that doesn't help I'll go to the next step of testing components
Since we're talking about VTEC actuator hanging up, I might as well pull the valve cover to visually inspect it, and while I'm there check the valve clearances and do the compression test while I'm at it...
I would love to figure out the way check the fuel pressure, but it seems I would have to replace Honda the specific pressure hose with a Honda specific adapter.
Also I got my boroscope camera with me so I'll inspect the cylinders and valves when I pull the plugs out.
My better half will be away till Friday afternoon so I have 2 full days to play with my toys )))
Just talked to my old friend at Honda (car) dealership where I used to work, and he is the guy who actually knows how things work internally, not just a parts swapper...
According to him on the 2 sensor engine the 1 wire is for the idiot light but the 2 wire sensor is used to monitor VTEC operation and if it doesn't see desired effect (pressure drop I guess) VTEC doesn't engage, or delays engagement and you get some funky power surge issues...
So I'm gonna install old style sensor and wire it up and it should take care of things, but I will not have the idiot light...
Not important really and I don't think you're monitoring it anyway, but since the oil is being returned to sump from the cam follower control gallery, i would expect the pressure to rise when the solenoid is activated to lock the followers together.
Looking forward to seeing how this shakes out.
Good luck.
Good luck.
When VTEC kicks in there's a pressure drop because when the spool valve opens it sends oil down to the actuators, think of a shower faucet when someone flushed the toilet, I just don't know what it needs to see on the sensor inputs at that moment. Waiting for 2 wire sensor and plug, it should be here Monday.
If I disconnect the sensor wires I get an alarm pretty much from the start, code 26, when I wire them back the way it was (with all 3 wires going to same sensor, which doesn't make sense) I get alarm at high RPM (in neutral on the muffs).
I just finished soldering and heat shrinking all the connections to eliminate any possible bad connections and took it tot he lake, I can cruise for 20+ minutes at 5,500 without any issues (I think I was starting to annoy the locals as I kept going in circles) but when I accelerate to 5,800 it sets off the alarm in less than a minute, same code 26 all the time.
My OBD2 data link came in but I accidentally ordered a wrong one (Honda 6 pin) waiting for a 4 pin adapter to show up, also probably Monday, so I can finally check the data stream.
I just realized that my earlier search for DTC26 might have been a victim of Ai or wishful thinking, pretty it told me "oil pressure signal" because I had it unplugged, I just searched again and it gave me a generic answer "sensor out of range" but in reference to ECT.
I have a manual for BF90D and it jumps from DTC25 to DTC 41.
Also overheat light comes on when it starts beeping, but I can't remeber if CEL comes on...
Might be chasing wrong symptom with DTC 26 being a memory code and I'm simply overheating due to bad t-stats, which are leaking BTW.
Both T-stat covers are warped AF and leaking water when I'm running, ordered both and exhaust manifold anodes for good measure.
One more trip to the lake last night and I think I'm starting to understand that this is an array of issues instead of the single one, and some are possibly created by me trying to fix things.
My initial thought was that I will find something what will be an "aha!" moment led me on the path along which everything that I discovered I treated as confirmation of the same problem, somehow related to the oil switch, including DTC, which I didn't realize was stored even after the battery is disconnected, so I cleared it.
Test ride on the lake last night confirmed overheating, no DTC.
Overheat alarm is unrelated to original problem, but was created by me making things better: while fixing the wire splices I pulled all 3 temp sensors and checked resistance, noticed that 2 of them were very crusty so I scraped them clean, I'm guessing the crust was acting as insulation that was masking the overheating at max rpm, now that they are reading more accurately the alarm goes off after a minute at full throttle, goes away almost as soon as it comes back to idle, so it's very marginal.
Did the vinegar bath yesterday, couldn't lower the engine deep enough into a trashcan so I kept adding water and I think concentration was too low as not much of the scale was coming out, still better then nothing I guess.
Still have what now seems like VTEC cycling in and out, now more notable around 4,000 rpm when the engine isn't fully warmed up, couple minutes after start up, pretty significant fluctuation, after a while it's less of a surge but still there.
Got a busy week coming up at work and I might not be back home till next Sunday, so it's gonna drive me crazy all week, not knowing if the thermostats and oil pressure switch are gonna fix this, or if the DLC adapter cable works. If it works I could probably leave my wireless OBD2 adapter under the cowl and have live data while I'm under load driving the boat
Your issue is a lazy slow reacting O2 sensor, in this state it does not log a fault. This has nothing to do with the vtec
why does it only happen at certain RPM range? I would expect it have minor impact, but RPM change is pretty significant before it fully warms up.
I'll order O2 just to be sure, but it may take a while coming from Yumbo, also Honda has two sensors listed for the same motor, looks like one is updated version, but I can't say for sure
I know from experience, I've worked on Honda for 24 years. Typical O2 faults, rough idle with alarm is failed heater circuit, slight surging between 35 and 42 revs, failing sensor, slow to adjust and no alarm
Do you know if those sensors I listed are backwards compatible? 003 is for the older PRE-NMEA ECU that I have and -H01 of for the 2017 and up, only $20 difference from Yumbo, quite a bit more when buying here in US
Always buy according yo serial number, if the part number is different then there is reason for it
My engine is a later model DK4 and has a 1300000 serial number while ECU is from older engine, DK1 or DK2, with 1000000 or 1100000 serial numbers. Also, Honda lists three different oil pressure sensors for the same serial number... I'd say it helps to understand why they change serial numbers and what fits what.
I was reading somewhere that DK1 and DK2 were all interchangeable and later updated versions work with older engines, they just have faster data processing, better maps etc.
Replaced both thermostats, still overheating after a minute or two at WOT, I guess a vinegar bath is next?
Got Heal-tech hooked up and O2 is mostly hovering around .900 but at times drops to 0 and stays there.
I see 3 ECTs on the engine, but data stream has 4 and the last one is reading -40ºC, but it's not on the diagram.
Data shows Baro sensor and it's stuck at 8psi, MAP works fine, 14 PSI when not running, about 8psi at idle.
Fuel pressure is fine, had it running at 5,500 under load with gauge hooked up and it stayed around 46psi, I think it shows 48 when I unplug the vacuum hose from the regulator and 40-ish at idle
