I'm asking this as an academic question so I can understand what's going on inside the motor.
I assume the reason for changing the oil is because the motor oil becomes contaminated with Seafoam (thinned petroleum distillates) and dissolved carbon. But the only way for this stuff to get into the oil is by leaking past the rings. Isn't it? But rings are pretty tight fitting.....that's how compression is created. So I would think that only a tiny amount of anything is getting past them into the crankcase.
The other way of thinking is that a carboned-up cylinder may have stuck rings that are allowing blow-by, hence, dissolved junk gets into the oil. Is that how the oil becomes contaminated?
