Care to discuss why you believe you have a bad TPS?
My thoughts are that there IS some obvious difference between the two....
...the most significant being the WOT voltage.
In my experience with automotive TPS the 4.8 volts might....MIGHT.... be "out of range"
I typically like to see 4.5 volts maximum but I have seen higher on perfectly running engines with no complaints. While the higher signal voltage DOES match up with being a possible out of range condition and does match up with what you are experiencing.....
.....would this make me condemn the TPS?
In most cases, YES.
BUT....in MOST, or at least many, automotive instances I can swap out a new TPS for under $50!
In THIS case, it's around $400!
It's your $$$ and your call but if it were me and I was staring at a "known good" part that I could try before spending the cash....I would do the swap first and test the performance empirically.
Good luck.
Well, as a guy that has worked on cars, trucks, heavy equipment and even military tanks (my job in the U.S.Army)....I have grown VERY leery of AM (after market) parts in the last couple of decades. But, having said that, I recently put an AM TPS on my beloved old Gen1 Durango 4x4 and it works just fine.
So...your Ebay find could be a real bargain. I hope so anyway.
But your decision to do the swap and see how it runs first I think is a wise one. That will definitively answer the question.
If you do decide to try the AM TPS, make dang sure that the internal circuit matches that of your Honda before powering it up. If it doesn't and you end up sending the reference volt output directly to ground that might possibly destroy the ECM. Not trying to scare you but I really don't trust our replacement parts stream these days at all!
Please keep us informed about how it goes.
Good luck.
It's got to fit pretty much exactly in the hole with the slot in the sensor matching up with the end of throttle plate shaft.
You don't want any air and dirt to leak past the sensor.
The one in the picture you sent has slotted mounting holes for adjustment.
You would want to adjust the voltage values to get as close to the ones you measured on your good engine by sliding it under the screw heads.
You could actually try slotting your bad sensor's mounting holes and try to get a better adjustment on that one the same way. I've actually seen that done before as a good ol boy fix when a replacement wasn't available.
Do any adjustment with the screw heads as tight as you can and still allow the sensor to move. That way, when you cinch the screws, the settings won't change as much.
