Blacktimes
Hi Guys, took the boat out this weekend and starboard BF200AK2 is consuming about 6 litres/hour more than the port engine. Last time I took the boat out last week both engines had a perfect match. Temperatures are the same. Ran the Dr. H and no faults, no fault codes. Engines have about 130 hrs on them. No smoke or anything, starboard runs perfect but with higher consumption. I don´t think it is anything major or that a compression check needs to be done, my feeling is maybe something stuck, could it be the IAB? Also played around a bit and perfect match until 2100RPM, that´s when the split starts, under that both are a perfect match. I normally run the engines at 3400-3600RPM and only troll entering and leaving the marina. Any ideas? Thanks!
