steve88baylinercapri
I have a 88 Bayliner Capri with the 5 liter and King cobra outdrive. My issue is every time I put the boat in the water when i shift into gear the motor dies. When its out of the water it shifts fine into gear without the motor dieing. I recently switched to electronic ignition and put a new coil, plugs, and wires on. When I switched to electronic I did so because of the issue. I replaced distributor when doing so also. I checked the continuity on my ignition interupter switch and the other switch thats tied into it and both check out. Im at the end of what I know what to try. PLEASE HELP!!!!!!!!!!!!
