Running issue with 2008 BF225 with 1000 hours.
wlin98004
This is a great forum and I learned a lot from it. Thanks for everyone who chime in. Here is my problem.
In the last few months, I had my engine "stall" out on me when running at ~4000 RPM. Engine shuts off with alarm. I did not pay attention to the pattern of the alarm or the light indicator. Normally, I just turn off the engine and restart it. It will run normal for the rest of the trip. It happened a few times and never bother me enough. In the last few trips, when I started my engine it will idle a little rough while I am still on dock preparing things. After a few minutes, I noticed the engine will suddenly rev up a bit and run smooth, but alarm will come on. I turned off the engine and restart it. The same issue may or may not repeat again. I did not think it was a serious problem and continued with my outings. On my last trip, when I stopped my engine to fish and tried to restart it, it will not keep running. It will start but dies right away. I pumped my fuel prime bulbs a few times and engine will start "normally". The problem got progressively worst through out the trip. Towards the end, even pumping the fuel prime bulb will not keep the engine running. The only way I can keep the engine running is to start it and throttle it up right away. Once I get it running at more than idle speed, I can run my boat without issues for a long time (> 30 minutes). If I left it in idle, it will give alarm and quit. I need to solve this problem before I go out now.
I do all of the boat maintenance myself. The motor is a 2008 BF225 XA with 1000 hours. I just changed motor oil, oil filter, low pressure fuel filter, thermostat, gear oil a few month ago. I did not change the high pressure fuel filter this time. Not sure if it is a fuel issue (I doubt it), a fuel filter issue, or a sensor issue. Any recommendation in diagnose this, is appreciated. My boat is in the water and it will be a pain for me to get it out. Normally I only take it once a year to do maintenance work.
I see references to Dr. H device for reading diagnostic data from the Honda outboard. Can someone give me more information on what Dr. H is and how to get it? I am familiar with ODB2 reader for cars.
Is it overheating? Maybe at low rpms there is not enough water circulation. Have you inspected your impeller? Is there a strong telltale stream at idle?
No, it is not overheating. Very strong pee stream. I will double check with a cold engine start to see if the problem is there or not.
Been busy at work this week. Next week I plan to pull the boat out of water. I bought a Healtech OBD-H01 tool. Hope that will allow me to read the code. I doubt it is an overheating issue. If it is a overheating issue, the motor should not continue to run once it is up to speed. I am having problem when the motor is idling or at very low speed. It feels like it is not getting enough fuel. I suspect my fuel line, fuel filters or fuel pump are the cause. Anyway to further pin point the issue to one of those fuel parts? Thanks.
My 1999 130 has been very sensitive to an overheat alarm at cold startup after I did a major vinegar flush. A small chunk of salt seemed to appear and trigger an alarm. Most times on restart, it worked fine, sometimes I had to clear the telltale outlet of a small chunk. The issue went away after a bunch of usage. Your ugly thermostat may be an indication of a cooling system issue rather than fuel?
Finally I got sometime to look into my issue. The engine still stalls when I started it. It starts fine, but dies right away. I pulled the code by shunting the service plug. It reads 1 and 14. When I turn the key, I can hear the fuel pump or some "noise" for about 2 seconds. The prime bulb is pretty firm. Makes no difference if I prime the fuel bulb or not. After I cleared the code, I run the engine a few times. The problem is still there, but no new code. Here is a video showing the problem.
engine issue
I was able to keep the engine running by reving up the engine right after the start. Once I increased the RPM, the engine runs fine. I was able to take it out and run it without problem. While I was out, the idling is still a bit rough, but it doesn't die on me. I am debating to pull my boat out of the water or not to get to the bottom of the issue. It is a pain for me to pull the boat out. I don't have a trailer and have to rely on someone else with a big truck. Since increase the idle speed seem to make the engine run better. I am debating to just adjust the idle speed and take a gamble. On the other hand, I don't want to be stuck out there.
Any input on what the possible issue could be? I don't see any overheating sign. The tell tale is strong and engine stalls regardless if I started hot or cold. Can the fuel pump gone bad? If it is bad, can the engine still run without it? Fuel filter blockage issue? Thanks for all of the help.
I changed the low pressure fuel filter in April 2026 and the high pressure fuel filter in 2025. I am debating to pull boat out or just up the idle RPM for this season.
Good new. A local marine mechanic pointed me to the Idle Air Control (IAC). It is a valve at the top of the engine and it is super easy to take off with just 2 bolts. The screen is caked with deposits. I sprayed WD40 on it and blow it clean. Engine is not stalling anymore. It still idle rough at the start at about 500 RPM. After about 1 minute, it will smooth out and rev up. Hopefully the boat will hold up until end of the season. According to the mechanic, I should have the valves checked and adjusted on next service.
The engine is no longer stalling at start, but it idles really rough and the RPM gets very low to the point of stalling. I rev up the engine and everything is fine. I went out with my wife, it runs fine but did stall once while running at ~4000 RPM. I don't see any temperature alarm. I did see the battery light indicator came on and off a few times. I turned off the engine and restarted it and no sign of issue. Wife does not feel comfortable and want the engine run 100% before she will go out again.
My boat is out of the water now, I plan to give the throttle body a "deep" clean and change out the high pressure fuel filter. Any other things I should look at? I did buy the Healtech OBD diagnostic tool and plan to check the different sensor reading.
The engine start to stalling again. I need help on a few things.
1. I took off the IAC and to my surprise one of the screen is "cake" up again. This is only from 2 hours of engine run since my last cleaning. Is this normal? Is there any way to clean inside the IAC?
2. I am ready to do a thorough clean of the throttle body. What is the best way to do it? Leave it in place and spray throttle/carb cleaner inside?
3. I found a small tube attached to a black/orange thing that is just hanging there. I don't see where this tube is supposed to be plugged into.
4. I did get Healtech OBD diagnostic device. Here is one of the run, not sure what to look for. Is there anything jump out to someone?
engine running recording using Healtech OBD
5. By the way found a leak on my port side exhaust manifold. Another thing to fix. Joy of owning a boat.
Thanks for any help.
Well one step forward and a few steps back. Here is my progress.
  • Got the gasket and anode for the exhaust manifold. Luckily I have a Honda dealer within 15 minutes drive and they have parts in stock.
  • Found out the mystery part (black/organe) is a check value. The tube is supposed to be hanging and not connected with anything.
  • Took off the throttle body and gave it a good clean.
I thought things are going my way, but then things turned. When I tried to put the manifold back, I realized I took out the exhaust guide seal when I forcefully took out the exhaust manifold. The exhaust guide seal guide should stay with in the bottom water jacket and that is why there is a warning to not "shake" the exhaust manifold on removal in the service manual (pg 5-118 step 7).
According to the service manual (pg 5-120), the exhaust guide seal should be change out every time. However, in order to change out this part, we need to take off the lower unit and the lower rubber engine mount (pg 12-57). This will be a really big job. Question for the guru here. Is there a way to put the exhaust seal guide back without taking off the extension case?
By the way, I am fighting with my lower unit now. I could not get it off.
I decided it is too much risk to take off the engine mount to just replace the exhaust seal guide. I am going to see if I can push a new exhaust seal guide down from the top. Any advice on how to do this?
Just realized there is a search feature on this board. Found the following threads that are very helpful.
https://www.marineengine.com/boat-forum/threads/install-manifolds-need-help.444756/
https://www.marineengine.com/boat-forum/threads/bf225-internal-anodes.435490/
https://www.marineengine.com/boat-f...ust-guide-seals-replacement-necessary.398075/
Glad that I did not start to take apart the engine to replace the exhaust seal guide. I am quite sure I will run into more issues. I will try to clean up the parts and hopefully I can put the manifold back.
By the way, I still have a stuck lower unit that I need to attack. The fun of owning a boat.
Just for reference. Here is what I did to get the manifold back in place. First I cleaned up the base really well with a wire wheel/brush on a drill. Got rid of of all old corrosion. I put in some gasket material in the grove and the outside ridge of the exhaust "ring". Made a note where the flange comes out in the base. Cut off the seal on the gasket where the flange is such that I can drive the exhaust seal guide into the base. Used a trim tab zinc anode as a driver to drive down the seal guide. Cleaned up the exhaust pipe with a wire brush on a drill. Applied grease to the seal guide and the exhaust pipe. Line up the manifold and the base. Used a piece of 2x4 and drive the manifold straight down into the base. With the new O-Ring, it may take some force to accomplish this. I had to take off the fuse "box" so I have room to line everything up. Here are some pictures to help to understand the process.
I also won another battle with my lower unit. I tied a rope around my lower unit and hang 2 50lb concrete anchors off it. Spray with PB blaster and bang on the case with a dead blow especially when you are frustrated. After a few days, I finally won the battle.
I cleaned the IAC valve and the throttle body. Changed the high pressure fuel filter and lower pressure fuel filter. Need to put everything back and hopefully the engine won't stall anymore. The war continues.
The metal gasket behind the manifold prevents water gets into the exhaust chamber. I would think the water tight function of this gasket is critical. What is the torque spec for the 8 bolts and what is the pattern to tighten the bolts. I could not find that information. Also do you need to apply any sealant on the gasket?
I know nothing about this or any 225 but what you are doing looks like good common sense to me.
What size are those 8 bolts- maybe I can find some that size on my 130 and can advise what torque they are on it from my Honda shop manual?
For a sequence to torque, on something rectangular like that, I tighten from the middle outward to the end. I do it in increasing stages, start light and do them all once. Then tighten them in that order again, up a notch, do this a few times, then the last time use a torque wrench to whatever number you find out is correct. Maybe someone else has that number.
For sealing in an exhaust area, can’t hurt to use a high temperature RTV?
Hopefully you’ll get some more replies.
Don
Thank you Don. Now, at least I know I am not talking to myself. The bolts are 8x40 and 8x60. The way to install the manifold and the gasket will make putting sealant around the exhaust holes almost impossible. The gasket is of coated metal material.
Good news. Boat is back in water. It is idling well. However, it is very hard to shift. It turned out the engine is idling too high at 1100RPM. I adjusted the throttle cable and got the RPM down to 800RPM. Now it is shifting smoothly. Hopefully this war is over.
Just for reference. Here is a way to do a complete vinegar flush of my engine. Here are the parts you need. You can get them at home depot and Costco.
- 4 gallon of vinegar (4 Monks brand) from Costco. I dilute my solution 5 parts of water to 1 part of vinegar.
- a big container. You can get a big container for under $10.
- a sump pump (the lowest power one will be sufficient.)
- 2 hoses. One to fit into the water tube going up to the engine. One to fit onto the tell tale tube.
- a few hose clamps.
Take out the thermostat on both side of the engine. Put all of the hoses into the container and you will have a closed system, so none of the solution will spill out. Any sump pump will be strong enough to push the solution through the engine. Run the system for a few hours and it will clean your engine out.
on
I thought the war is over. However, the other side won't give up so easily. I am still have some issues. The engine starts fine and run for 20 - 30 seconds at about 1000 RPM. Then the RPM will come down and engine dies. I can hit the gear disengage switch and ramp up the engine. It will run at high RPM without "stalling". When I just start the engine, the shifting is really hard. This happens even at low idle RPM (< 1000). Once start up I can run the boat at 4000-5000RPM going at about 20 - 25 knots without issue. When the engine is warmed up, the issue is mostly gone.
I have cleaned IAC valves and throttle body, changed high and low pressure fuel filter. Once the engine is warmed up, the idle is smooth. Any pointers on what is the possible issue? I won't pull out my boat this time. I already missed a month of fishing. I will not miss August.
Check your O2 sensor. That controls your fuel mixture. Also take your air inlet box on top of the motor apart. There is a screen in there that might be plugged up.
