So I was pulling my plugs on my Honda 250 (2013 with 1000 hours) and one of them was VERY hard to remove. When I looked at the plug it appears that the first thread was a little crushed/galled. Trying to screw it (as well as other normal looking plugs) back into that particular hole was VERY tough, so I stopped trying to force it.
I am going to try and use a spark plug chaser to clean up those threads and if that doesn't work then I will try using a back tap thread repair tool.
Any advice as I have never done this before. Should I use any type of grease or anti-seize on the tools?
My research on anti-seize for spark plugs is giving me lots of different diametrically opposed options. I understand that the torque needs to be less if you use an anti-seize. I am wondering, though, given the salt water environment and dissimilar metals, if I should be using a non-copper or non-nickel based anti-seize, say something like Jet Lube for this?
Thanks!
Thanks!
