As it says I was replacing some fuel hose and found a piece of metal/material about 1 inch by 1 inch with a slight curve. Curious and seeing some small shavings under the flywheel so pulled it off. Yep 1 coil coming apart and 1 magnet broke in half where the screw goes in it. Can the be replaced and are they even available. AAARRRGGG. I have a Honda dealer around the corner sorta Ill give them a call. Im all ears for input.
Thanks Brad
Thanks Brad
