Georgiaguy
I am restoring a BW outrage – It has a 2000 Evinrude E150FPXSIF on it and and I think it will be a good motor in spite of a lot of negative press. I am presently addressing lower unit.
The lower drain plug is frozen and I have not been able to loosen it. I have tried about everything -- it is a slotted flat head screw so buggering it up needs to be avoided. It is stainless steel
Thing I have tried:
Using a larger screw drive with head that fit the slot more fully and tightly
Spraying with PB blaster and letting it sit then repeating it – to drips off so it probably needs to pool and soak in – it is on the boat -- I might have pull the lower unit and lay the unit on its side
I heated it with a propane torch that didn’t work – I hesitated to use acetylene because it is seated in aluminum that melts with strong heat
I tried an impact screw driver --- the kind you hit with a hammer – still didn’t budge
Anybody got a good idea on how to loosen this plug??
Thing I have tried:
