contender31
Morning I have 2 1990 Crusader 454 350 hp carburated FWC engines with 1350 hrs on each. I recently bought the boat and am considering repowering due to recent mechanical failures. Yesterday I did a compression test and need your opinions on the results - ok here goes -
Port Engine # 1-132, #2-135, #3-130, #4-110, #5-130,#6-130, #7-110, #8-140 -- Starboard - #1-115, #2-110, #3-90, #4-100, #5-105, #6-85, #7-130, #8-120.
These numbers were done with a cold engine. Could not due a hot engine test due to the heat generated in the engine room. My question is simply this - does one run these engines until they die or replace now before they die? The options for replacment are as follows - 1. long blocks - , 2. redo the heads, 3. swap out the old engines with lesser hr used engines ( note - I have a line on 2 engines with appr 400 hrs on them). Does anyone have any experience with US Engines.com ? they claim that they can increase the hp to 420 and increase the torque from 300 to 500 on these 350 hp engines.
Your comments would be greatly appreciated
Thank you in advance
