diver_dave
Advanced Contributor
The direction for taking compression in my 1990 Crusader manual says to operate the engine until it has reached proper operating temperature. This may have changed in more recent years.
Erich
I don't have a strong opinion on hot, warm, cold for doing compression testing. I can see a case for hot if the engine uses forged pistons, that tend to expand when warm, more than cast. We are generally all running cast pistons. Also, another down side when cold is the oil is more viscous, making the starter a bit slower, more labored and maybe providing a better piston ring oil seal, than when running at temp.
More important is to use the same process for each cylinder, since its the relative psi delta that's relavent. In florida right now, it's 90 degrees, so it's not likely this particular engine is laboring with "thick" oil
