I will definitely check the ports out, make sure everything is clean, l also went and purchase some gauges to hookup as well. I didn't get a Chances to set the timing or adjust the carburetor while it was running, l let it run for about 15 min or so, l will run it again this weekend and make all the adjustment. Any advise or suggestion on setting the timing etc......
Best advice that I can offer, is to not make the mistake of setting BASE advance ONLY, and not taking it any further.
I see well seasoned marine mechanics make this very mistake.......... They set BASE, and look no further.
I'd suggest that you see your OEM ignition timing specs, and then physically check your progressive spark advance up to the full-in RPM, and make a comparison.
Your harmonic balancer will need to be marked off.
If you know the balancer diameter, you can purchase a Mr. Gasket decal that installs directly onto the outer ring.
Now you can strobe your timing marks at idle, and up to the limit RPM and compare to the OEM specs.
If you want to take it a bit further, you can jot these numbers down in approximate increments of 300-400 RPM, and then plot this out in graph form.
This can be compared to the OEM curve.
At the risk of redundancy, BASE advance is BASE advance, and all day long.
We fire up on, and idle on BASE advance..... that's all we do on BASE advance.
The important numbers will be the progressive advance, and the RPM at which the system if full-in!
Not enough advance will seldom cause anything but poor performance, and poor fuel economy.
Conversely, too much progressive advance, and/or excessive TA (total advance) may cause detonation, of which can be very destructive.
This is of particular importance for the Marine Engine where loads are more constant, and are maintained for much longer durations.
NOTE: Checking the progressive and TA can also be done with the digitally advancing type timing lights, of which I will not use for Marine Ignition timing.
By doing the above method....., we get to view this in real time/real degress, and with less risk of an error, IMO.
I know that the guys who use the digitally advancing timing lights love them. I mean no offense, it's just not my preferred procedure.
