Greetings to all,
I recently purchased a relic of and old wooden hull boat (1978 Skiff Craft), 350 Chevy, MerCrusier Alpha One pre '92. I had a supposedly good marine mechanic (does repair on the side out of his house) go through and replace the regular things like gimble, bellows, shift cable. He had to pull the engine because several of the expansion plugs were corroded and leaking. He also suggested replacing the impeller while we were doing everything else, which made sense. On my first test run the engine I thought was running a bit to the hot side of the gauge in idle-to-slow running mode, but then it over overheated to red within a minute or so after I gave it open throttle. I took it home to analyse. With the lower unit in a water tub, after initial start up in idle, the the temp gauge goes into the red within 5 - 8 minutes. I know water is circulating through the system. because I see it discharge from the out drive exhaust port. I'm pretty good a trouble shooting some things, but not being a mechanic limits me where to go from here. I later found out the guy I had do the work is known to scam people and often doesn't really replace the concealed parts and pockets the money. Before tear into the lower unit myself, I just wondered what else can cause the overheat situation (for example... could be the thermostat?). Thanks in advance for anyone's advice.
Classic78
Classic78
