Had the little whaler out yesterday - ran good, pee stream was good, motor purring like it suppose too - all was well...Finished the boat ride and put it back on the trailer and took her home to clean her up......until I screwed up...
I had the boat on the trailer and was washing all the saltwater off - I then put the muffs on the motor, taped the hidden place under the cavitation plate.....then turned the water on and began flushing the motor out....
Pee still good, water strong...motor running good.....
My phone rings and I go answer it...I walk inside the house, take care of a few things, hearing the motor running fine..... After about 4 or 5 minutes I go back outside and motor still running, the water is still on, but I notice that there is nothing coming from the pee hole, I quickly look at the muffs and they have slide down slightly, not covering the intakes like they should.
I shut down the motor, get the muffs where they need to be and start the motor back up - she fires up ok, and now she's peeing - but man is it hot water.......after about 30 seconds, the water is normal temp -
I am hoping I didnt destroy the motor by letting it run while I was in the house - and it not peeing, i have no idea how long it was like that...
Is there anything I can look for, or is there any sign/sympton that i can check to see if I tore it up or overheated it?
I didnt hear an alarm - but I am not sure this has an overheat alarm....
Any advice or information is appreciated....
Lesson learned - stay with the damn boat - to heck with the phone...
thanks guys
jeff
thanks guys
jeff
