Uggggggggg TMI AF TGIF WTF...............really a baggie!
No comment..... if Jack doesn't understand this one, well..................
The rubber does not care where it is or why
That is absolutely incorrect!
Rubber or like compositions that are folded or bent out of normal shape, will take a "set" over time. This "set" often causes fatigue that results in small fissures or fractures. IOW, causing this accelerates the eventual failure of the component.
For those of us who are perhaps more into the science of this, and who are perhaps more experienced, we understand the "why" we do not want to do this!
Electric WHAT? where did that come from.............. I did not read anything regarding electric heat protection or power outages,
Geese!
Put your eye glasses on ...... this was related to Kim's post #4. I assumed that electricity would have some involvement in the "heating" of heated storage.
If you know that the heated storage was wood-fire produced, then I stand corrected!
And by the way..... what do Geese have to do with this? Don't they fly south for the winter???
No value added AGAIN!
Oh and if you are visiting AMAZON for reviews on winterizing a marine
engine...............I would rethink commenting on any of this!! try real world experience!
Jack, you have misunderstood the reason for my Amazon write up, of which has caused you to entirely miss the point.
I won't bother explaining it to you, but I'll bet that the rest of the guys got it!
However, I will give you 25 points for using the term "Engine"! Good job..... kudos!
Leave your outdrive in any position you want to AS I DO AND HAVE DONE FOR MORE THAN 20 YEARS and have done on many hundreds of others for the same amount of time!!!
Do what you want with your own boat...... but that's a disservice to anyone would may trust your judgement regarding their boat!
If you want to introduce antifreeze, only thru the outdrive (NOT "AF") (another stupid acronym)
AF would be an "abriviation"....... not an "acronym"! (an acronym offers a phonic value)
.................... then go ahead and hope you do it correctly and hope all the water is expelled. Some do and have no issues............some do and replace the
engine blocks and manifolds............your choice!!
Congratulations........ You get another 25 points!
This is Precisely why I challenged the Amazon advertisement and took advantage of their "customer review" option!
If you were to read my write-up, you may have a better understanding of why I felt the need to comment.
Every Spring these unsuspecting users learn that these Winterizing Kits did do what they had hoped for.
As I said, if you just remove the drain plugs on the block (make sure you poke thru the cast iron build up so the water drains out on both) and the plugs or lower hose on the manifolds and back flush the incoming water line and empty the LARGE water hose from motor water pump to thermostat housing you should be good (Each and every time you use the boat) in the winter if you will see below freezing temps..........And do not for any reason put the plugs in a baggie..............that is for marine businesses who have warranty concerns when winterizing not for the individual boat owner and not for me who winterizes hundreds of boats each and every year.
Jack, why is it that YOU can repeat yourself, but according to YOU if I repeat something, it's agravating to you?
Pot calling Kettle black perhaps????
The procedure I posted in post 2 is exactly what is required and is exactly what I have done on THOUSANDS of pleasure boats under 24 ft in length used in cold climate environments for the last 25 years+. I have never had a failure................Never.
Good for you! That's the goal.
You were simply challenged regarding leaving the drive raised up during the lay-up. This is not adviseable, and you now know why!
