jasoncalleja
Hi today went out with my rib with Honda bf90d and while was ruining at about 5300rpm engine stopped. i thought that i may have had a rope around the propeller when i trimed out the motor i noticed that water was coming out from the cowl i lowerd the motor and opened the hod and a Lott of water came out i noticed that the engine was all wet i tried to restart but engine was hard to turn so i puled spark plugs and gave him some turns and water come out from the pistons. after i towed up the rib i dismantled all the engine covers and found that pie pipe was stuck so this was the caused the engine flood i gave the engine a good wash with fresh water and soap and dismantled all wiring plugs gave them a good water repellent and a good air blow and reassembled all i also sprayed penetrating oil in bore and in the air intake and sprayed a Lott too under the fly wheel i also opened the head cover to check for water in the head after assembled all the motor and a lot of water repellent all over the engine i started the motor and run good now i will replace engine oil to be sure that all water is drained completely. do you think i have to do any other maintenance or just back to the sea and go
thanks Jason
thanks Jason
