Hello all, I have twin '13 Honda 250 on a 30ft CC. Replaced O2 sensors on both under warranty, BUT the last 2 years I also have had oil pressure alarms going off on one my engines when throttling down from WOT. This usually happens around 3000-3100 rpm after WOT. Replaced the LP and HP oil pressure sensors last season, but the alarm still goes off, however not as often but still a problem. Have tested oil pressure using manual gauges, and also run good oil and change filter every
season plus maintain the engines properly.
Did a check on endplay two years ago, but Honda claimed it was within set tolerances.
Honda Norway wants us to check cables from the sensor to the ECU, but I wonder if this might be an ECU issue? Grateful for any help!
