Bike wrench
I need some help - checking the cam timing.
The unit is the 2007 Honda BF50A 50hp
I use the community pontoon boat once per year for about 8 days. Last year, the BF50A fired up like a Honda and ran well. This year it started out with a notchy cranking, then spins like the plugs are pulled out. Upon further inspection, a bunch of wasps built a mud nest around the timing belt pulley on the crank. I think the belt has slipped a few notches, explaining the loss of compression. I got all the mud out, and checked the belt, it looks OK.
What I need to know is how do you check the timing belt position/cam timing? I see the T mark on the cam pulley, and matching T mark cast into the head. I also see the T mark on the outer edge of the flywheel.
Can anyone please give me a good description of the correct method of checking/adjusting the timing belt?
Also, is this an "interference" engine (like most Honda bikes)? Will the pistons hit the valves if the timing is off far enough?
Thanks to all for any help. This is supposed to be my #$@&*% vacation! I just want to pull the tube around the lake for the kids. ARRRRGH.
