Winnercuddysport
Having some issues with my bf225. There are a few things going on, so instead of trying to type it all out and explain it, I figured a quick video would be best. That way y'all could see exactly what is going on. Unfortunately, the alarm I wanted identified didn't happen. Instead, it was a COMPLETELY different alarm...FML. so I guess help in identifing that problem would be good. And if the delay in the ignition starting is in the switch or something else. There are 2 videos because after a minute or 2 of waiting, the motor ran great. Started fine other than the delay in the switch, and no alarms any more. However, if I go try again in a few weeks, the alarms will be back. It seems to throw them the first few startups then it's fine. Also, it revs up high in the beginning the settles to normal rpm and wants to backfire on startup on the first few cranks. It has never done this before either. In short we have this:
1) delay in switch when trying to crank
2) battery light does not come on even though batteries read good. (I have checked the connections)
3) solid beep when cranking a cold motor so it's not an overheat alarm
4) the new alarm that I have never had come on until I made the video a few minutes ago- beeeeeep beeeeeep beeeeeep beeeeeep continuously until I turn off ignition.
Anyway, I know this is loaded but if you could take a look at the videos and let me know what y'all knowledgeable fellas think. It would be greatly appreciated!!!
https://youtu.be/wtmHXUgyS7U
https://youtu.be/UgpoXXbwVFM
