hello I could really use some help. My strb Honda BF200 has a constant alarm when I go above 3000 rpm and the oil light goes out. I turn the engine off and restarted it with no alarm at idle. i used the procedure to pull codes and nothing came up.if it was the oil pressure sensor wouldn’t it throw a code?The oil was 3/8 of inch high on the dip stick prior so I changed the oil and thermostats hoping that would fix the issue, but it did not .I appreciate any help I can get on this issue
