Hi All,
I am trying to figure out what caused an engine to die.
Carb'd 454 Mercruiser with an Alpha 1.
The boat is trailered, never stored in water, and flushed after every use, raw water cooled, operated in salt water.
The manifolds and elbows are 2 years old.
The engine was test fired on the trailer on muffs to make sure we could hot launch from a busy ramp.
Got to the ramp, fired right up and out we went. The engine ran great then developed a miss. Pulled the hatch and saw one of the brand new Sierra spark plug wires had fallen off. Replaced it, went out further, same thing, but different wire. Eventually stopped and recrimped all the wires.
Engine was running great then developed a miss due to a wire coming off again, brought the boat off plane and killed the engine. It started to diesel, which it has never done before, and ran-on for a few seconds while the backlash of the wake bounced off the transom.
Fixed the last plug wire and tugged on them all to make sure we had no issues.
Motor wouldn't turn, not even a tiny bit, it felt hydrolocked. Got towed in.
Pulled the plugs when we got home, and water poured out of all the cylinders. Rolled the motor over and it just blew tons of of water out.
Replaced the plugs and it wouldn't start, turned over funny like it had no compression. Checked the timing and it didnt jump.
Pulled the manifolds, they looked good, gaskets looked good, elbows looked good.
This my theory.
When the engine died and dieseled, it counter rotated and sucked water through the flappers, through the exhaust valves, and hydrolocked the motor, bending the connecting rods in the process.
I can't think of any other way a running engine with no signs of water intrusion on the manifolds would go from running to locked.
Does this sound like a feasible explanation?
Any input appreciated as I am being told that marine engines can't counter rotate and suck in water.
This my theory.
