Hi Chris,
I have been having trouble using this site so couldn't answer you. They tried to fix it but I think the problem is on my end.
Anyway, very common for those seal rings to not fit after removing.
You should always have a new replacement on hand because of that.
I had tried to tell you that the accelerator pump circuit should be cleared. If it's clogged, even a little, the carb won't work properly. DON'T probe the jets or passages with sewing needles or anything too large. NSDON is correct about using wire bristles but be very careful NOT to break one off!! Those are very brittle and can be impossible to remove once inside a passageway.
If the accelerator pump circuit needs cleaning, you should start with the delivery nozzle that is in the brass tube that juts out into the air stream at the carb inlet.
You need to prop open the throttle (I use a pocket screwdriver) so that you can see the brass tube from the engine side of the carb. You need to insert the end of the spray can's plastic straw directly over the nozzle at the end of the brass tube to reverse flush it. Fluid should exit the passage that feeds the tube.
If Fluid won't flow, you need to locate the entrance of the passage and spray into it. Often, on a badly plugged carb, you will need to spray into the brass tube from supply end and then try spraying from the nozzle end several times to clear that tube and nozzle.
You will know they're clear when you spray i the the feed end and fluid shoots out the back of the carb several feet. As in 6 to 8 feet!
If not, just keep flushing back and forth until that happens.
Watch your.eyes!
On the 20 carb, there's also a "main jet tube" that sips fuel from the float bowl. It's a vertical brass tube with a very tiny jet that can clog easily. If you can't get both of those tubes flowing properly, you might be looking at another replacement carb. Those carbs are very sensitive to contamination.
Sorry for the book like post. Just getting you info you may need.
