I just bought a boat with a used BF75 from 2008. Im quite the perfectionist on maintenance and because it will be running in salt water I will flush the engine after each use.
I saw that the flush port should be used and the engine should be vertical. Every video I see the boat is on a trialer. Could there be any problem if I flush the engine while the lower unit is submerged? Should I rather tilt the engine and then flush?
