Is your opinion based upon test data or a WAG? I don't use E-10 or E-15 fuels in my engines. I am a believer in Seafoam reducing fuel varnish/gum deposits in my engines that get stored over the winter. Haven't had a fuel related problem since I began using it years ago.
I agree about using pure Shell gasoline. I also use Exxon, Mobil, Sunoco and will use BP if the aforementioned fuels are not available. Thanks for the test data; very interesting.
Your welcome - What does "WAG" stand for?
All alcohols, being very strong solvents, cleansers and degreasers, will clean and "reduce varnish/gum deposits".
With E10 readily available, you don't need to buy a gas additive to accomplish that anymore. 10% ethanol is more than enough to keep engine clean.
(Actually 1% is plenty, 10% is too much).
Their recent 2011 study/report, backs up another large study on Mercury engines and ethanol back in 2003, called
"Marine Outboard Driveability Assessment to Determine Impacts of a 10% and 20% Ethanol Gasoline Fuel Blend" completed by Orbital Engine Company.
My opinion on Seafoam is based on the product's ingredients and numerous reports I have received from our customers and visitors (Fuel-Testers), over the past 5-6 years, that had problems with E10 due to Seafoam - (Of course I have no way to validate their reports - but they all seem to have the same type of problem -gumming, clogging of carb, milky substance, etc.
Seafoam "Motor Treatment" product contains 10-20% IPA (isopropyl alcohol, CAS# 67-63-0) + petroleum distillates (naphtha).
They (Sea Foam Sales Company, MN) may have other products now?- If they do I would still check MSDS before using them - (Actually I would never recommend using them) - Like many additive companies I find their website and literature very deceptive and/or misleading.
EG. Their product(s) contain alcohol, but on their website they deceptively state,
"...Sea Foam® continues to manufacture its additives using the same
100% pure petroleum formula developed by the company’s founder, Fred Fandrei back in the 1930’s...." -
http://www.seafoamsales.com/
Product is
NOT 100% pure petroleum.
Note: Many additive companies are deceptive - But the ones that blatantly lie, I could never trust or consider using/testing their products.
If you believe you MUST use an additive with E10 gas (usually you really don't need them unless you have a specific problem),
always best to use products that do not contain alcohols or strong solvents.
Examples: Maxima fuel storage stabilizer is probably my personal favorite in the "retail" additive category (racing industry company), plus many use Stabil and Startron, and there are many others that are much safer than Seafoam with E10 gas type.
Hope this information is helpful - Anything I write here is my opinion (unless I quote or copy a report or something like I did above),
My E10 info is based on many years being directly involved in ethanol/gas industry/renewable energy (ethanol fuel testing) - and since I interact with all engine-type owners and all types of businesses (from government to engine manufacturers and others), from all over the world- I believe I have a very accurate assessment (and reliable opinion) on what's really going on with ethanol, both good and bad.
Additive Products is NOT the solution to E10- At best it's a "band-aid" - Protecting your right, to choose to buy ethanol-free gas for marine engines, is the most effective solution/remedy regarding E10.
