I have a BF30 on a pontoon. The boat is in the water at a dock. Yesterday the tell tale went from a stream, to a drip then nothing. I have completed a seasonal maintenance two months ago with new impeller, housing and gaskets as well as changing lower end gear lube, oil change, filter, thermostat. Six months ago, full carb clean and rebuild as well as new fuel lines, water separator and fuel tank.
Didn't think the motor was overheating but used trolling motor to get back to dock.
I tried weedeater string...nope
Tried single thin wire...nope..
Took a cheap one gallon sprayer. Pumped it up with nothing in it but air.
Removed the wand right after the on/off handle.
Stuck the telltale hose in the on/off handle and turned it on.
I could hear the air whooshing through and then bubbles came out in the water from the front of the lower unit right below the water line.
Started the motor and have a good stream again.
maybe luck, who knows, but I'll take it..lol
hope this helps
hope this helps
