matt.speedtriple
Hi folks,
Following reading on of the threads on here then I`m considering fitting a bolt on cylinder head temp sender to my bf90d so I can see the engine temp at a glance via a gauge.
I`m in the process of renovating an Icelander 18 fast fishing boat that I`ll be fitting an outboard pod to so I keep the higher freeboard at the stern but will struggle to see the telltail stream to insure it`s pumping water ok.
Now the question I have is what the normal operating temp would be so I can see about buying the correct gauge to suit?
Here`s a link to the cylinder head temp sender I`m thinking about:- http://www.asap-supplies.com/brands...-head-outboard-motor-temperature-sender-90405
Cheers, Matt
Cheers, Matt
