tugcapitan
Hello Honda crew,
Have a 2002 BF9.9 making oil with fuel. Upon draining oil after winter, noticed red discoloration ( use red dyed marine fuel). Thought maybe it just leaked a bit while on it's (correct) side over the winter. But after oil, filter, fuel filter, water pump, thermostat, sparkplug change and carb rebuild, ran it for a week and noticed it made oil again (red like fuel). Ran great throughout.
Preliminary research on net indicates;
-damaged fuel pump diaphragm
-running too cool, fuel getting past rings.
Understand possible fuel pump diaphragm problem.
But, too cool problem usually associated with an engine that was not broken in correctly, and this one has run fine for years. However, symptoms supporting running cool include
-lots of salt deposit found when installing new thermostat, and when running, discovered threaded water flush port leaks water slowly. Imagine this means water flush valve bad. Corrosion on bolts under water flush port indicates it must have been leaking unnoticed last summer too.
Are these two problems related?
Anyone else experienced these engines "making oil" with fuel?
Recommended course of action?
Thanks in advance
Thanks in advance
