bf30a fuel requirements
PaulMc
just had my carby's stripped and cleaned...new set of coils put on...the mechanic tuned the carby's and mixture screws....ran the motor and she's all good to go
put her in the water finally and could not start the motor...was just about to put the boat back on the trailer when I finally got a fart out of her and it ran like a dog and worse than before the work was done.
left the mechanic a dirty NOT happy message to contact me
I normally do my own services but I will not pull apart carbs pistons ect as I dont know enough about them and then get a mechanic
i have had to since reset mixyure screws and carbs to get the motor to run reasonably but not perfect and it has left me thinking I may be running the wrong fuel with a too high octane...at present using 98 premium
my question is...according to the user manual it is ok to use E10 fuel (10% ethanol) or just normal unleaded at 91-95 octane but anything above 86% octane
for a 97 model motor which fuel should I be using....
cheers for your input
That engine should run ok on 87 octane. I don't really think 98 octane would necessarily affect the way it runs but it is really only intended for high compression engines and is certainly overkill for that outboard.
Good luck.
I generally tell people they can use anything they'd use in their car.
The difference here being that cars are MUCH more forgiving when it comes to sitting unused. With a 4 stroke outboard, if it's going to be sitting unused for more than a couple weeks or so, you had better be running some sort of fuel conditioner - or plan on draining the carbs.
