Mutinous_Scallywag
Last week, our tender needed a tow because it suddenly wouldn't crank. Turning the key on the throttle box produced no reaction, not even a click.
Yesterday I finally cracked open the throttle box, expecting a neutral safety switch in contact with the throttle lever. But it's actually in contact with the fast idle lever. The lever cam pushes a black plastic pointer, which in turn pushes the plunger switch. But a quick test revealed that pushing the lever wasn't actually doing that.
I put everything back together, and this time pushed the fast idle lever past its natural resting position while turning the key. The motor started.
If that's what I have to do from now on, it's not a huge deal. But it's still weird that it went out of spec like that. Is there an adjustment screw? Did a piece break off the little plastic pointer?
