metal-chicken
My 225 didn't get used at all last year and I'm having a couple of little issues this year:
As per an earlier post the tilt/trim indicator is reading much lower than it should - it was fine when the boat went into the water in July but suddenly started mis-reading.
At the same time the rev counter is occasionally reading high by about 400rpm - When I turn the engine off it drops to about 400rpm but when I switch on the ignition it drops to zero. I will then sometimes over-read while running, but not always.
Sometimes when running steady at around 3900rpm the engine note will suddenly change and accelerate a few 100rpm without me touching the throttle - kinda like a cylinder has kicked in (but it doesn't feel like it's missing when idling).
Yesterday once when I accelerated from standstill it wouldn't go above 3500rpm and was surging - I stopped the engine, restarted and it was fine. I must have run about 15 miles at 4000rpm after that with no issues
There's plenty of fuel, the main fuel filter/water separator is new but one thing I have done this year is to use 3rd party low and high pressure fuel filters - I won't be doing that again!
The o2 sensor is dead but I'm not replacing it until next spring as I thing they just 'go off' over time with our usage here.
I can't really test much as the boat is on a mooring for the next week or two and then it comes out of the water. We've not much use this year thanks the the shocking weather in July and August here in the UK.
Any thoughts? Could a poor earth somewhere cause these things?
