Hi,
I have a 2006 BF225
Lately my engine sometimes start shaking (RPM drop +-100) when it run.
This normally go away after 10sec-2min.
Most time is this happening when the motor have stay at idle for some time, or have stop for a wile and start again.
I hear/feel this shaking/rpm drop when I accelerate from idle, but also when I add some throttle in 3-4000rpm range.
I have change out the low pressure and high pressure gas filter, change out some gass hose, check thermostats, check/replace sparkplugs.
Yesterday I try when it shaken to add fuel pressure with the hose manual pump, but the was not any difference.
Earlier I change the exhaust pipe (Service 56) and a few O2 sensors, bidshaft bussing failure, change the timing belt, adjust the valve, change out the start cable wire, +++
When the O2 sensor fail, I usual get a alarm at idle.
Yesterday I also try to read out the code with a scs short connector.
I got then one blink every ca 3sec, I then reset it and it did not trow any new code at the dock.
Later I did a testrun and got some shaking/rpm drop and did a new scs short connector test, this time the Mil stay on and did not blink.
Any suggestion what to do?
I have a 2006 BF225
