aussiegrunta
"Can anyone help with this...
"Can anyone help with this... Went out the other day and after 15 min travel had alarms sounding. The engine warning light was flashing, I have the 2 warning lights one eng and one battery light.. The engine didnt seem to be over heating as the tell tale had a good flow of only luke warm water and the temp light on the throttle was not on. Went home and spoke to my local dealer who told me how to retrieve the codes with a bridge wire across the red diagnostic plug near the ecm. Came up with 6 short flashes. Water temp sender or open circuit in temp circuit. I removed the sender and found a lot of salt deposit covering the tip of the sender, Cleaned the gallery out and replaced the sensor thinking i had fixed the fault as no alarms sounded went run for for 20min on the hose.. But after a test run on the water for 15 min the alarms sounded again.
Now when brigeing the plug i have 6 short 2 long and 4 short flashes..
I have ordered a shop manual online but have too wait for shipping and we are right in the middle of a prime barramundi season which really sucks.. So need help bad..
I have checked the water pump, thermostat and sender resistance all ok. The engine doesnt seem to be getting hot, tell tale not hot and no steam from the exuast.. But it is strange that it takes 10 too 15 minates of load times to fault, temp fault ??????
My engine serial BZBD-1301114 (ON THE FRAME) and BEBD- 1006458 on the valve cover can any help would be much appreciated... cheers grant...."
