Ayuh,.... Did you encounter any Weedy waters that day,..??
No. Clean and clear water.
The extra weight in the boat with the family + now a full fuel tank will cause the boat to run the way it is now, Keep in mind your comparing how the boat ran with just you in the boat after the service with less fuel.5) 5 days later on Sunday, took the boat out with family, noticed problem planing.
If you read the OP's first post, he describes his boat as a 2005 Bayliner 245 with Mercruiser 5.0L and Alpha I drive.List of possible causes of low WOT (Wide Open Throttle) rpm.
1.... Understood!Hi Rick,
1.... Agreed, I have been a bit piece-meal with the data. I have to apologize for that. I'm fairly new to power boating so a lot of things are new to me...
2.... I was trying to keep the original post "condensed" to make it more readable (obviously, a mistake)... Also, up until the first few replies, the ONLY thing that I had considered that I "changed" was the leg maintenance. Once someone suggested other things like gas/bottom/etc, I realized that there was more than one variable in my situation.
3... As you pointed out, in my original post, I said that it requires more RPM to stay on the plane. Later, I said that I had less power. I didn't mean to be confusing with this. In my brain understood the two statements to be equivalent. My reasoning: My limited understanding of engines (which could be flawed) says that higher RPM = more power output to prop. Therefore, if I used to be able to plane at ~3.2k but now I can't, then there must be less power available to the prop at 3.2k RPM. Also, if now I need 3.8k to just stay on the plane, then now there must be the same power at 3.8k RPM that I used to have at 3.2K.
4..... So, I'm looking for reasons that now after service and gas, it takes more RPMs to make equivalent power... Feel free to correct me if my understanding is flawed...
5.... As to the weight increase on the Sunday... I'm not positive you aren't right, but my gut says this isn't the issue. First, one correction. I bought the gas on the way home from the marina with the lift. I had to motor for ~45min with this additional fuel and didn't notice a problem planing. So, the increase in weight between no problem and problem was just the family and snacks. My wife is ~125lbs as you guessed (good one), but my 2 kids are both under 5 so the total for them is less than 100lbs (snacks included). All other gear was equivalent (no extra water or what have you was added) So, the weight difference before and after the problem is less than 250lbs.
6.... From my experience (which is limited), weight hasn't made a significant difference to the boats performance. I have had between 1 and 5 adults (say 200 -> 1000lbs) on the boat and I've always been able to plane at between 3.1K and 3.3K RPM. So, I'm not sure how the small difference of the family could cause this much difference in performance?
7.... Just to satisfy my curiosity.... can you explain why you don't think it could be the gas? Assuming there could be either water in the gas, or gunk, or just lower octane?
Continued thanks for putting up with me..
1... and your points in the above that relate to Scheffer's issue is??????1... Hard to believe that with all the knowledgeable people on this forum, so few are aware that the mpi version of the 5 litre engine in 2005 and up is rated at 260 hp and a large percentage of bayliners used it in their 24 foot boats.
1... if I`m not mistaken, the 5 litre in 2005 was rated a 260 hp which is same as older 5.7.
Should get that boat on plane with no problem. If it is taking considerably more rpm to get it on plane, then something has to be slipping or leg is trimmed too high or tach is simply gone wonkie.
2..... Fact is, his symptons aren`t power loss as much as asking why the motor APPEARS to be reving higher to do the same job.
3..... Better question to ask might be what SPEED he used to plane at and what speed he needs now.
The one thing that does ring true to me is that I bought gas directly after the leg service... I feel like this important snippet of info is getting lost in the thread somehow. I realize I don't have a much experience with engine tuning/troubleshooting, but it seems like the quality and condition of the gas put in a motor must have a big impact on that engines performance... otherwise, top-fuel dragsters would just use good old regular gas from the corner station
5 minutes after putting the boat in the water for the leg maintenance, I filled up with gas from a fuel dock I'd never been to before. It seems like if there was a problem with this gas (dirty/water/low octane) it would adversly affect the performance of my engine. Can someone please help me understand what the effect of bad gas could be on an engine? Also, if you are convinced this is NOT the source of the problem, help me understand why you think that...
Well put, Bill!If it takes 700 More rpms to do the same speed, yer draggin' something that's causing a need of more horsepower to move the load at the same speed...
Totally agree--talking it to death will not fix it.Have you opened the engine cover for a quick once over?
I must agree! I'm out until this one gets back on track!OK, I am backing out of this one as the problem has changed from needing more rpms to plane to now loosing rpm and dropping off plane.
Yes I believe so, But honestly i'm not 100 % sure if this idea would affect the running attitude of the boat or not but i suppose it could.Question, could his O/D been reinstalled not all the way in or down causing a loss of power or technically torque?
like somebody trying to get on plane with the outdrive not all the way down?
This was one of my thoughts as well, Water conditions would definitely make the boat run like this, along with the added weight in the boat.Normally you are going with the tide. This one time you were running against it.......
Ah, That's what makes this fun especially since we're nearin winter time now, lol.Lots of energy spent on this problem with very little diagnostic time.
Continued "piece mealing" isn't helping anyone! All of this could have been explained in post one!
