Could the prop have become damaged during this?
Hi Ricardo, When the leg was off, it was just resting on the pavement. There was no noticable difference in the prop condition before and after the leg repair. How much damage would need to be done to make a difference like this? Seems like it would need to be fairly significant...
ALL:
One important point I forgot to mention is the sequence of events leading up to what seems to me is a simple loss of power.
1) Tuesday morning I motored from my marina to the marina with the lift approx 1/2 hour away. No problem planing, boat performed as always
2) Boat went on lift, mechanic did work, boat back in water. During this time, we didn't even open the engine compartment so unlikely anything changed in there due to work
3) Took boat to fuel dock which is about 10min further from home marina, filled up. Tank was only 1/4 full when I pulled up, so I got about 40 gallons of gas in the fill up (60 gallon tank). No problem planing to the fuel dock. Note that I have never bought gas here before.
4) Motored back to home marina (~45min) still no problem planing. I can't remember how fast I was going here exactly. I might have been running a bit higher RPMs than normal since I was running late by this time.
5) 5 days later on Sunday, took the boat out with family, noticed problem planing.
I really think this sequence excludes a problem with the prop/gearing/bottom. Otherwise, I would've had problems planing immediately after the mechanic did his work. In my mind, it also points strongly toward the quality of the fuel I got from the different fuel outlet.
What is the effect of old gas (or low octane) on engine performance?
Would it cause the motor to have less power/torque at a particular RPM? If not, what effect does it have on engine performance?
Any idea how long would it take the old/bad gas to filter into the engine and start causing problems?
If water were in the gas, would it take longer to see the effect due to mixing and/or separation and/or clogging the water separator filter?
One final note: I never tried to see what my WOT RPMs are. Neither before or after my problem started, so I can't really use that as part of the diagnosis.
thanks again...
