Hi,
The ball bearing was meant as a check valve to trap fuel in the pump chamber. It is now useless as it is IMPOSSIBLE to put it back and have it stay put.
As I've stated many times, these accelerator pumps are pretty much junk. Useless junk....inasmuch as they don't really work well even when brand new.
If you desire to have the pump function as it was intended by Honda, you will need to buy a new float chamber and accelerator pump "kit".
With a new float chamber you will see the little ball bearing press "captured" into the pump chamber inlet orifice. That orifice is at the end of a little "tunnel" on the bottom of the float chamber. That tunnel is how fuel gets to the pump chamber.
Otherwise, save your money, throw the ball bearing, away and put the thing back together. Make sure the little rubber bellows is in good shape and get back to boating. You won't miss that pump working "correctly" even a little bit.
I will say though that if the accelerator enrichment tube gets clogged, the engine won't run well. I can see where keeping the pump operational and shooting fuel out the the tube orifice every time you twist the throttle it WILL help in keeping the tube and orifice clear.
So, it's your call.
