I have a 1989-ish Mariner 9.9hp with a few issues.
I've had it for roughly 8 years now and just recently started experiencing issues.
First the engine started to start hard, took a lot of pulls or a shot of starter fluid. Sometimes it would bog and die out, once it would run - it would rev up nice and push the boat well then start to lay down and run at about 3/4 throttle and down on power. I started to poke around and noticed the enricher leaking. Replaced the enricher, solved the fuel leak but did not solve my running problems - at all.
So I treated the fuel and stuck with using my trolling motor until I had sufficient funds to fix the engine.
Took the boat out of storage this year and not to my surprise, it runs the same. I pulled the plugs & the top plug was bone dry, but brown. The bottom plug was brown and barely wet. I let the plugs dry, swapped them and the boat didn't run differently. When I pulled the plugs this time, the top plug was slightly wet, the same as the bottom plug now.
So I swapped coil packs side to side, checked the plug wires, everything looks good.
Started it up, idled okay but it still does the intermittent sucking sound and sounds like a major miss every once in a while, when I put it in gear and give it throttle, it sometimes bogs or makes the sucking sound, almost shuts off and then comes back to life.
I've noticed when pulling the plugs, the top plug is significantly warmer than the bottom plug. The bottom plug doesn't feel warm at all sometimes.
Not sure what to do...any advice?
