Goneagain4
Newbie member, just joined the site. Hoping to get some help on neighbor's engine.
Pontoon boat with the Honda 60 4 stroke on it, approx 225 hours. Original owner since new. At 3000 RPM or higher, the temp alarm sounds and lights up red. It has the round gauge with the green oil light on while running, temp warning, check engine light. Keep it below 3000 rpm and it goes all day with no alarm.
Since he had not done any maintenance, here is what I did:
1. Changed oil and filter. Changed foot oil with new o ring seals.
2. Replaced complete water pump kit, cup, impeller, housing, etc, OEM kit.
3. Replaced thermostat, OEM.
4. Replaced temp sending sensor, OEM.
5. Removed/inspected O2 sensor, spark plugs. Plugs look normal, all 3 plus the sensor are clean.
6. Replaced fuel/water separator, no water or debris in filter. Engine fuel filter is clean, float at bottom of filter.
7. Repaired starter brushes, that was done first when it would not turn over.
Don't think it is a true overheat. You can keep your hand on the thermostat housing when the alarm goes off and engine block does not feel overly hot. Switch it off and restart and everything is normal again until you exceed 3000rpm. Tried to use infrared temp but unit was not working. Telltell shoots good stream. Engine runs smooth, have not done compression check but plugs look good and power output is normal.
I think the issue is also load related. Only alarms when in gear under load, neutral at 3000 rpm and it does not alarm. The alarm will go off even before engine has a chance to warm up good. Start it, idle for a couple minutes, go to 3000 and it alarms after about 10 seconds. Shut off, restart, good until you exceed 3000 again. Does not require cool down to reset alarm. Neighbor says ongoing problem started at 4000 rpm but now is down to 3000rpm.
The engine is clean, used in fresh water and kept on cradle when not in use. I'm the only one that has worked on it so far but I'm running out of ideas. Any help here would be appreciated!
