FinnBoater
Hi
First time Honda outboard owner, with a new-to-me 2014 BF80. Yesterday when returning to shore, the trim and tilt wouldn't work at all. Thankfully, we had the option to leave the boat at a jetty with enough water to not damage the motor. As the trim/tilt just plain stopped working, I suspected an electrical problem, e.g. blown fuse. This morning, I checked all the fuses (by the way, is there a fuse diagram somewhere? The owner's manual just has instructions on how to change them). None were blown. And when I then tried the trim, it worked just fine.
Although the problem is not active at the moment, a potential intermittent problem of this sort may lead to problems if getting to shore is prevented.
Does anyone have experience with this sort of intermittent failure of the trim/tilt, and what should I check to minimize future problems?
Thanks in advance!
Cas
Thanks in advance!
Cas
