coastalcapt
Quick run down: 3 batteries on boat. 1 starting battery, 1 house battery, and 1 additional house battery. The third (additional house) battery is on a separate switch but they are all in series, its a 12 volt system. I had the starting battery blow up (battery fluids all in the battery box/case) so went ahead and replaced all three batteries. Been running on that for about a month, no problem. Started noticing the volt meter on the tach showing only about 12 volts and in some cases 11.8 volts while making way. Pretty unusual because it typically runs around 13 to 13.4 volts when making way and usually hold around 12.4 in idol. The other day, after having run the boat hard all day, anchored up to get some shut eye, upon waking up, the batteries were run down and would not crank the motors. Had to emergency pull start the starboard motor and then was able to crank the port. Shortly after making way for 10 min, went to idol and the low voltage buzzer went off, was around 11.4 volts. Had to make a long run back to the dock and did so hovering around 11.8 to 12 volts. At the dock it dropped voltage again in idol before loading on trailer.
I have removed the 3 batteries that were run down and was able to charge them up on an AC charger. I did replace them with brand new Optima batteries (dual purpose) just to rule out batteries. I was thinking its the alternator/s but upon testing them per instructions in the service manual (checking resistance between 0.09 to 0.14 ohms) they test fine, right around 0.1. I was doing some testing with the boat out of the water today, it seems if I just run the port motor, my volts hold at about 12.4 and that's with all my equipment turned on and running the motor at about 3000 RPM. When I add the starboard motor it will drop it down to 11.8 volts and putting it up to 3000 RPM it will maybe jump back to 12 but back down to 11.8 volts. It seems like something in that starboard motor is draining or the alternator isn't charging? I'd love some ideas if anyone has any before I put it in the shop. Would love to avoid that as there aren't any good Honda dealers around anymore.
