“What would the two have in common at the controls?”
Should be nothing, they get power separately, the throttle and shift cables are separate, they do share a key panel but other than the plastic panel the wiring should all be separate. I do have a Fell overboard device that interrupts the kill switch however it makes a bunch of noise when it shuts down the engines so I doubt that’s an issue (it’s wired correctly with the resistors to support twin outboards).
My other thought was to install a digital fuel pressure gauge in place of that relief screw. Is there a specific set of pressures I should see for the various stages of startup (priming, cranking, running) or is it always going to be 40ish psi?
