burmbuster
Had the number 3 injector fail a few years back. This time the symptoms were identical. I left it running and unplugged the #1 injector and nothing changed. Still rough idle. It also lost over 1300 RPM. So I ordered a injector and installed it. Nothing changed. Checked that I had fire from the spark plug cable. Pulled the plug. It was a perfect tan in color. It smells like it running rich which is a little different from when the #3 went out. Checked continuity from the ECM plug to the injector connector. Its good. I attempted to check voltage at the injector wire connector while running and did not read anything, however I unplugged another injector thats working and couldn't read anything from that connector either. True RMS Fluke meter being used.
ECM? Any ideas? Any way to pull codes?
Any help is greatly appreciated.
Thanks,
Brad
Thanks,
Brad
