thanks but I don't have the four lights just two.Well, "EVERYBODY" does not know what they are talking about. The only thing that will shut down this engine once running is an overheat. And when running on muffs, they overheat a lot.
Pull codes, record codes, reset ECU, then run until you get an alarm, then pull the fresh codes and let us know what you see. Procedure is attached.
It runs ok except at idle. there does seem to be a bit of vibration howeverFYI - engine will run OK if HO2 sensor is shot, it just won't run efficiently.
I got the dealer to run the diag and it said 02 sensor which I replace with after market and OEM and go the same result except the OEM shutoffs the engine after the beeps and the other just keeps beeping.Try JGMO's reset technique. If that doesn't help and without the 4-light console, you are shooting in the dark. Get to a dealer or Honda repair shop who has a working Dr. H to get full diagnostics.
Yes I am using the muffs. I will take it out I guess and have them install the four light hardness display if it's not ok. ThanksAre you testing this engine on muffs? If so, then you are probably not getting enough cooling water, so the engine is shutting down from overheating.
In the long run, it may pay you to have a dealer install the four-light harness and display. You can run a lot of diagnostics yourself with that set up.
Did you figure it out?Yes I am using the muffs. I will take it out I guess and have them install the four light hardness display if it's not ok. Thanks
