Hey guys,
Ive recently bought a boat with a 2006 BF225 with the 30" shaft 400hrs
Ive done my fair share of research before making an account and posting. I have read codes, seems no codes are stored. The oil and filter was just changed by the previous owner and it is to the full mark on the dip stick. Mobil 1 oil filter.
I am getting a continuous alarm I believe is the oil pressure alarm(green light goes out). If running at 3500-3900 rpm it will take 10-20 minutes before I get the alarm. I can then kill the motor and restart for another 10-20 minutes before it throws the code again. If I run at 4000-4500rpm I never get the alarm but lets say I throttle down to 3000 and back up to 3500 right away it will also throw the alarm. The motor certainly has oil pressure, oil is clean, no noises, and I've put 9 hours on it since i bought it with this issue. If oil pressure was critically low i doubt it would have made it this long with no shavings or noises.
any way to bypass the oil pressure sensors(high and low) or should I just run a thicker oil with a honda oil filter? The motor runs good other than tripping this code and going into limp mode.
Any help is greatly appreciated, thanks!
