Jtorrey852090
<p>
This problem started by simply turning the key on at the boat ramp on my Honda BF135A and poof no power, so far I have replaced the Ignition switch, switch harness, PGM-FI main relay, inspected all grounds, took all wires off batteries except main power and ground, batteries are charged. I have read in other forums that the trim tilt relay may be causing this short to ground but if I replace the 10A fuse the tilt function works fine on the remote handle and on the engine. Only when I turn the key to ON position does the fuse blow. Any help is appreciated John</p>
